SEA KING 5HP what year fuel oil mix
alderman
I just aquired a Sea King 5 HP two cyl. model # GG18801A can anyone help with year of manafacture and fuel oil mix. ? Old motor seems in good condition but don't want to build a fire in it untill I have proper oil mix. It has not been started in 3 years. Thanks in advance
Paul Moir
Re: SEA KING 5HP what year fuel oil mix
Alderman, first - Welcome to Iboats.<br /><br />Your Seaking is a 1963 5hp engine, built by the Gale division of OMC. Since OMC also owned Johnson and Evinrude, your 5hp is mechanically identical to an early 60's Johnson or Evinrude 5.5hp. So parts are plentiful and inexpensive for your engine. Good news eh?<br />The proper fuel:eek:il mix for your engine is 24:1 87 octane gas to TCW-3 rated outboard oil. Spark plugs should be Champion J6C gapped at .030". Lower unit oil should be SAE 90W outboard gearcase oil.<br />Once you've got it started, you should immediatly replace the water pump impeller. They go bad just sitting there, and should be replaced at least every 2 or 3 years notwithanding use. Iboats, NAPA autoparts, or your local Johnny/Rude dealer can fix you up with a new one for less than 20 bones. Take apart your pump first before ordering parts, in case you end up needing a new housing too.<br /><br />Good luck!
alderman
Paul: Thanks for the info and the good advice on the water pump. I am sure the water pump needs to be replaced. Thanks for the welcome to iboats. I will be hear often. Ray
