Sea King 7hp Clinton
Mictn42
I have a Model J700 1106 B Serial# 366049 this is a 7 hp motor made by Clinton Engine Company
I have been able to get the motor started and realize that I should rebuild the Carb but was wondering if the Carb on this motor was used by other manufactors in small engines so i would be able to find the parts locally instead of haveing to go through the CEPCO company in Iowa, (not that i haven't had good luck with them)
Like most people I guess I am always trying to do something on the weekend and don't like to have to wait to get the things I need to do a job.
The only numbers I have are some that are stamped on the Carb itself....LMB 165......and..... 470 982
klicknative
Re: Sea King 7hp Clinton
Prime Line carb kit 7-02020 is the one you need.
Mictn42
Sounds like a man who has gotten Carb kits before....was it for a Sea King as well?
I will also be looking for a fuel pump rebuild kit any idias on that?
klicknative
I have a 7.5. Discount Marine has fuel pump kits. Clinton used Walbro carbs on most of thier engines.
jinxedagain
i have aquired amontgomery ward with a 7 h/p my problem is that i can see no way to get lubricant into the bottom unit as it has no oil plugs can anyone help me thank you
steelespike
To me if there are no plugs put her upside down and remove the cover clean it out and fill it to the seam.I have aftermarket manuals that cover Clinton from 57-80 no reference to motors with no drain fill plugs.
