Sea king 9hp
Sunsetlaker
Hello everyone,
Just purchased a 1979 9 hp seaking for my kids to use on the lake. It has not been run for about 10 years and they did not know much about it. Questions are: Model k900 5106 D Sn KTV 52 309 D. What is the fuel mixture for this motor? The motor is air cooled but is there a water pump on these motors? The lower shaft appears to get hot when it is running. How do you change the impellor if there is one?
F_R
Re: Sea king 9hp
Don't know much about that one, but the answer is yes it has a water pump atop the lower unit gearcase. Parts are at:
CEPCO (formerly Clinton Engines) 605 E maple Maquoketa, Iowa 52060. If you phone you may get info with contact info. Be patient. Ph 563-652-2411. FAX 563-652-3427.
Sunsetlaker
Re: Sea king 9hp
I read that the water may exitout the exhaust tube along with the exhaust. Do you know if that is correct? is there a way to check?
steelespike
Re: Sea king 9hp
As far as I know water mists out the relief holes in the leg.
Water is circulated up the leg to a deverter/defuser and simply mists out the holes no direct piping to the outlets.
rofiling
Re: Sea king 9hp
Hi Sunsetlaker: I have clinto engine 7.5 hp I don not if is same model that yor have , but is impeller in the lower unit. You can find Ebay.com for #35.00 I think parts #220-130-500 .
