Sea King help
mobleybj
My grandfather recently gave me his boat. It has a Montgomery ward 5 hp motor. Need help finding a fuel pump and would like to know more about it. I have put a different vacuum ran fuel pump on it but i think it is pumping to much fuel because it will run good for awhile and the it will start to bog down a little and fuel will spit out by the idle screw.
Model #k5002106a
Serial # 711272
Type no 6027405R
Thanks Brian
F_R
Re: Sea King help
I think that is made by Clinton.
CEPCO (formerly Clinton Engines) 605 E maple Maquoketa, Iowa 52060. If you phone you may get info with contact info. Be patient. Ph 563-652-2411. FAX 563-652-3427.
Paladon
Re: Sea King help
It's just a guess, but the fuel leakage and bogging sounds like the float needle is not sealing.
