Sea king- (Clinton Mfg)
k900 5106A
XTV 52309 A
the whole throttle assembly was loose as it goes under the flywheel and attached to the drive shaft and i located a brass screw that seems to tighten it, this screw has a hole in the center and a spring behind it. Sure wish i had a manual then i might know what i was looking at, but i dont have the $ at the moment,.
Anyway if i tighten the screw then the throttle moves as it should. I get the feeling this screw affects more than just tightning the assembly. So i want to remove the flywheel so i can figure out whats going on there, but how do i turn the nut at the top without the whole thing turning down to the prop.
Another reason i want to get the flywheel off is that before i bought the motor muddobbers made a nest under it, so now as it runs dust and dirt come out and get into the air intake gunking up the carb. this is the 3rd time ive had to clean the carb from this, i can see dirt all inside of the flywheel just cant get to it.
any suggestions are appreicated
k900 5106A
XTV 52309 A
