sea king tank connector
phatmanmike
i moved this, i thought it would be better suited here, mods.<br /><br />hi folks, me again!<br /><br />i have 2 1970 mw/sea kings 3.5 made by clinton.<br /><br />i have misplaced the connector that "plugs" into the fuel pump comming from the tank.. it looks similar to the ones mercury used in the 70's, but a we bit smaller. you have to push it in and turn it to lock it to the pump....or how can i make mny own version.....<br /><br />where can a fine young man such as myself aquire one of these babes? are they even still made anymore?<br /><br />thanks to all<br /><br />m ikey
rickdb1boat
Re: sea king tank connector
Can you bypass it and go straight to the pump with the fuel line??
phatmanmike
i just did, i "rigged it " i just plugged a peice of smaller fuel line into where the "plug" was supposed to go, and now it runs thought id share
dajohnson53
Originally posted by phatmanmike:<br /> i have misplaced the connector that "plugs" into the fuel pump comming from the tank.. it looks similar to the ones mercury used in the 70's, but a we bit smaller. you have to push it in and turn it to lock it to the pump....or how can i make mny own version.....<br />
If I'm getting this right. This is the connector that is on the end of the fuel line that plugs into the engine? It's a female connector that you push onto the engine fitting and turn to lock?<br /><br />And, it looks like a current version of the Merc, but is smaller? <br /><br />If this is true, I had the same problem recently with an old (ca. 1968) Merc 9.8 hp that I had to rig up a fuel line for. The connectors that they commonly sell in non-boat (e.g. Kmart, etc.) stores "looked" right but was too big to plug into the engine.<br /><br />I went to a Merc. dealer and they had the right part. It looks exactly like the larger, current version, but smaller. Check there.
