sea king
podlar
i am having trouble adjusting the carburator<br />it will not run smooth seems to run real fast
corm
Re: sea king
Hi Podlar,<br />What model and horsepower?<br /><br />corm<br /><br />------------------<br />cubic inches = power<br />power = speed<br />speed = FUN
podlar
Re: sea king
Hi corm.<br />the model number is k5055106a i would say that it is about a 2 or 3 horse.
corm
Re: sea king
Hi Podlar,<br />I couldn't find that no. I would set the idle at 1/2 turn open and the high speed<br />3/4 to 1 turn open to start with. This is a guess going by the idea thaat you have a older style tillision carb. Hope it helps.<br />...corm...
podlar
Re: sea king
thanks corm i will let you no how it turns out. have a great day
betzingj
Re: sea king
Help.
I have a Seaking 5.0 hp motor made by Clinton. Model # 5055106A, Serial 1480536, Type XTV50505A, with a Tillston carb.
It was dry as a bone and not running for several years. I brought it home and got it to run for approximately 45 seconds one time and 30 seconds the next time. I cleaned the jets that I could find but can't get it to run for any extended periods. When it's not firing, it sounds like there is no life at all in it, like it's not even trying to spark.
I am hoping for any or all of several things:
1. Any idea of the year?
2. Why won't it run longer?
3. Is there a place to get parts?
Bob_VT
Re: sea king
Clean the car, check the fuel pump/pulse line, remove the flywheel, clean and regap the points, replace the plug. Go to maxrules.com for older parts.
tashasdaddy
Re: sea king
also laingsoutboards.com is a good source.
