Hello: I am trying to replace a rotten transom in a 1987 Sea-Nymph Fish&Ski; model # SS-175. I am wondering how to get at the transom thru-bolts that are hidden inside the aft port and starboard flotation compartments.<br /> I started trying to remove the splash-pan and go in from the top but it is thru-bolted to plywood underlayment.<br /> Decided to try removing the front panels from the <br />flotation compartments from inside the boat. This will mean removing some substantial rivets. One of these panels is hinged (port side) and houses the oil injection tank for the outboard. Then it should be a matter of digging out the flotation material and, finally, removing the remaining transom bolts.<br /> Is anyone out there familiar with this repair on this particular boat?<br /> Thank you
