Sea Pro 255
shimp19335
My Cuddy boat hatch is struck closed and I don't want to force it... Any suggestions would be great.
Thank you
Mist likely stuck on weather stripping
Undo both clocking levers
Back off the knobs on the struts
Go down below and gently push
Once open, lube the seal with silicone spray
If the hinge is corroded shut. Pull the whole hatch , remove the glass, and rebuild the hatch. Reglaze the glass, then reinstall.
