Sea Ray 220 CC repairs and reengineering
Bt Doctur
Restoring Sea RAy 220 CC
Currently restoring this for possable sale but it needed some re-engineering . Factory did some ridiculous things. They put the batteries on the port side thru a small opening
And left only the trim pump in this cavity
So considering the back panel was rotted and needed replacement a new panel was made closing off the cavity and mounting the trim pump there , with the hatch open you can still access the pump and res
Now on to the new battery position. After glassing in some support material a new battery base was added and now you just slide the batteries in place, no lifting and lowering.
Now the engine cover, another engineering disaster by the factory. Instead of using snaps they drill 4 holes thru the cover, then other owners added 6 more holes . This led to a lot of water dripping into the engine and rotting the timing chain cover.New timing chain, gears, and timing cover and pointer .After making a incision on the bottom all rotted material was removed and new plywood added and skin reglassed onto bottom
Once the bottom was done, filled in the holes with resin, sanded flush and finished sanding with #600
and got some White Exoxy appliance paint and proceded to apply 2 coats
Now for the engine hatch hinges that were loose and also had some slight rot under the floor I came up with this solution.On this hull the way it was built I cut a access holes to get to the area under the screw holes , will have that pic tomorrow,sorry. I made up this with some glass cloth and epoxy.
Measure for the depth to the screws ,held in place by the long wood , clear silicone and non corrosive 3 1/2 deck screws installed the hinge bases.​
Bt Doctur
New material orderd for the new back panel , trim pump wiring extended , motor should be back in Sunday
Ayuh,.... Lookin' good BD,....
I've been doin' the transom work on my ole Old Town Atlantis project over the last few weeks of warm weather,....
kcassells
No way... Bondo...Geeeeezzzz Got pics?
Bt Doctur
Should be able to run the engine and get it winterized and installed, then pump the tank dry for storage untill its sold ,quickly I hope
Motor has all brand new items and will be installing all new rubber at the transom.
Remount the battery switch in a convenient location this time too
