Hi,
I am taking up the floor on my 1979 19' Sea Ray. I thought the foam was dry until I got down to about 1" from the hull....foam was soaking wet. Now that I am removing the foam I am wondering if there are any fellow Sea Ray owners out there that could tell me if the foam provided any structural strength.
Also, I am planning to fill the area with some high-density polystyrene and making some weep holes in the stringers just in case water does manage to get in. Since I have some 3/4 inch plywood, I had planned to put it down for flooring...is this going to make a noticeable difference in the weight/performance of the boat?
Thank you!
Matt
Thank you!
Matt
