Sprockett
- Joined
- Mar 22, 2008
- 48
So I have a 74' Glastron Sportster, it has a 84' 90hp Evinrude hanging off the back, the boat is actually in pretty good shape and was out in the water last summer. We picked it up for about $2200, I've been all over the boat and the only place that I have found anything that caused concern was the transom.
I really didn't want to do this since we just bought the boat, but it's mine now and after drilling a series of holes to see where it had rot, I simply can't take it out until this is resolved. Someone had installed a fish finder and didn't seal the holes correctly, so it started there and has spread out. I actually found a wet spot going towards the outboard mount, that did it for me.
I could re-do the transom, but it will just rot again if it gets wet and it means un-capping the hull and I want to go boating dammit!!
, I'm already in trouble with the wife because I've been fixing things
. So after reading lots of peoples stories about Seacast it seems like I can get it fixed right, quickly, and be out on the lake this summer.
I've run the numbers for seacast and will be ordering a 5 and 2 gallon bucket so I have a little extra just in case, I'll post pics along the way as I make progress. I'm heading down the hardware store today to find:
My biggest challenge right now is removing the outboard, it's heavy and awkward and I don't want to damage it. I'll probably make a quick stand to put it on and am trying to figure out how to get it removed, I'm going to talk to the local shop today and see if maybe they can help. Once that's out of the way I can get moving on getting that wood out of there, it's pretty scary because the idea of a chainsaw on the boat is just not natural
I'll post pics of the work as I go along, one fortunate thing is that I can clearly see the shape of the transom, so as far as I can tell I don't have to do any upper supports on the sides. It should be a simple clean pour to get this fixed (once the woods out).
Once the transom is fixed I'm going to give the boat a quick paint job to bring the blue back and then re-mount everything. At this point I'll take any advice I can get, I'm terrified I'll kill the boat by doing something stupid....
So I'm off to the store to start picking up tools and wood for a stand.
-Paul-
- a grinder that I can put a cut-off wheel on when needed.
- an electric chainsaw with a long blade.
- some LONG spade bits or extensions.
- a mixer attachment for my drill.
-Paul-
