frustratedboater
- Joined
- Jul 10, 2007
- 481
Wonder if anyone can help me with some technical questions. I generally repair outboard motors, but was given a problem Seadoo Bombarder jet ski that won't start. Said it sputtered a bit...then felt a backfire like pop and that's it! Everything went dead.
He had put in a few 5amp fuses that popped, and fouled a few plugs trying to get it working. I serviced the carb (very little grit and grime, but cleaned up a nice). Also noticed that the idle screw (I think) was turned in all the way, and I gave it a 1 1/2 turn out (probably a universal setting)...?
The real problem:
With the key plugged in, I get nothing (fuses all good). With the battery being new, I jumped the two solenoid terminals and it cranks over nice. Am I looking at the relay or something as the problem?? How do a run a test on it? What does it look like in the box????
I would appreciate any advice on this or a picture showing the issue. Thanks so much,
~FB~
The real problem:
~FB~
