Seadoo Zip Tie holders coming loose
marcusknight
I recently acquired a pair os 1994 Seadoos and there are zip tie holders that have come loose from the hull. I am trying to come up with an appropriate adhesive or glue that would be appropriate for putting them back together. Advice? See the pictures.
Rough it up a bit, use acetone and wipe down the adhesive. If surfaces are clean and dry you could use silicone, it would probably last as long as you have them. Use 3M 4200 or 5200 for a more permanent fix
Grub54891
I'd clean it up, sand a bit to roughen it up, and epoxy a small plywood block to the hull, seal the wood with the epoxy, and install screw In type of ties.
Those zip tie anchors are available at most electrical houses. They are held in place with 3M VHB 4950 double sided tape.
The tape has a life expectancy of 20 years, your seadoo is 23 years old
