SEAFOAM
bernard410
I BOUGHT A CAN OF SEAFOAM AT NAPA BUT I DONT THINK I GOT THE RIGHT ONE IS THERE TWO KINDS THE ONE I BOUGHT IS AEROSOL AND THE ONES I READ ABOUT IN THE OTHER POST IS A MIX THAT YOU ADD TO YOUR GAS IS THAT THE ONE I NEED TO GET OR ARE THE BOTH THE SAME
Saskatoon2005
Re: SEAFOAM
They are not both the same, well like you said, one is aerosol and the other is a liquid that you mix. Does your aerosol read--Deep Creep? That is the aerosol. You can still use it to spray into the carb when idleing in a pail or on muffs. Do this but keep in mind that it will smoke like crazy, and the neighbors will think your house is on fire....LOL! Good Luck
Patrick
Silvertip
Re: SEAFOAM
It depends on what you want to use SeaFoam for. If you are decarbing, either product will work. If you are looking for a fuel treatment, Deep Creep is NOT what yoj want. You want the liquid (White can - labeled SeaFoam). Add it to the fuel tank for continued fuel treatment and fuel system cleaning.
artherm
Re: SEAFOAM
You can purchase both the "Seafoam,and the "Deep Creep" at "O'Reilly Auto Parts" nationwide. They are great products.
