seahorse 2 help
fec
just aquired a seahorse 2 Model #J2RCNE S/N#E5564815, need to find year of motor, also the engine was dropped on the front and the carb has a broken ear were it bolts up, need manual, carb, water pump impeller, prop. Also need help setting the fuel mixture and idle setting.
rolmops
Re: seahorse 2 help
Hello.<br />You have an eighty two rope start.<br />This is still fairly recent and you should be able to find everything you need at your local OMC dealer or your Napa auto parts store.<br />Other sources are e-bay. For a manual, there is the lower left side of this page featuring a button for manuals.This manual will answer all your other questions.
Joe Reeves
Re: seahorse 2 help
FEC.... The engine is a 1982 2hp Johnson. The fuel mixture is 50/1. Original and superceeded part numbers of parts needed are as follows. Any number may be used. Prices are approximate:<br /><br />Carb = 389941 = 397260 = 397387 = $250<br /><br />Water pump complete = 387362 = $30.00<br /><br />Impeller = 382221 = 6.90<br /><br />Prop = 316557 = 329568 = 125990 = $32.00<br /><br />I do have two of the water pumps assys left in my remaining stock. ReevesJ32@aol.com<br /><br />Carb adjustments are as follows:<br /><br />(Carburetor Adjustments - Two Adjustable N/Vs) <br /><br />Initial settings are: Bottom high speed = seat gently, then open 1 turn out. Top slow speed = seat gently, then open 1-1/2 turns. <br /><br />Setting the high and low needle valves properly: <br /><br />NOTE: For engines that DO NOT have a shift selection, obviously there is no NEUTRAL position. Simply lower the rpms to the lowest setting to obtain the low speed needle valve adjustment.<br /><br />(High Speed) Start engine (it will run pretty rough), shift into forward gear, take up to full throttle. In segments of 1/8 turn, waiting for the engine to respond between turns, start turning in the bottom high speed needle valve. You'll reach a point whereas the engine will either start to die out or spit back (sounds like a mild backfire). At that point, back out the needle valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest setting. <br /><br />(Low Speed) Slow the engine down to where it just stays running. Shift into neutral. Again in segments of 1/8 turns, start to turn the top needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running. Eventually you'll hit the point where the engine wants to die out or it will spit back. Again, at that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting. <br /><br />When you have finished the above adjustments, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
fec
Re: seahorse 2 help
Thanks for the help on the seahorse 2, I also have a evinrude 4 hp trying to find the impeller,manuals and how to set carb or is it the same as the seahorse. Only numbers I could find are 41060-E01488.
