seahorse 5 1/2 cd-15
redbird
Wheres a good site to order parts to replace water pump, carb kit and any associated gaskets, o-rings for this motor. A diagram showing part #'s with a blown up disassembly would be ideal. Thanks for any help.
samo_ott
Re: seahorse 5 1/2 cd-15
You can get them here at iBoats or try vintageoutboard.com
On the 5.5's you have to remove the powerhead to undo the shifter to drop the LU to change the waterpump.
redbird
OK thanks. OptsyEagle had already given me the heads up on the powerhead removal. I feel qualified enough to do the work, just wodering where a good shopping place would be. The closest Johnson dealer in my area is about 1 1/2 to 2 hrs away. I prefer to click and have it delivered whenever possible. Thanks again.
