SeaKing 45gg-9014A
egibsontx
Have purchased a seaking 5hp. She runs and as I would any new toy Im interested in doing the typical update on all necessary maintenance (ie, oil, grease, impeller). I would like to know where I can purchase an impeller that fits, and a service and parts manual. Please provide links to sites. Thank you for everyones help.
steelespike
Re: SeaKing 45gg-9014A
Motor is a 54 based on the Gale 5S10.
Fuel mix is 24:1 use TCW3 rated oil.I think the gearcase uses lubriplate 105 the modern version
of the original lube.I call the impeller a wobbler usually refered to as a rotor.And you may find them on Ebay or at www.aomci.org. Antique Outboard Motor Club.If the coils are plastic covered the system is likely the same as that in a similar year E/J motor.Routine parts are available here at Iboats under E/J motors.Original plastic coils are likely failed or failing.
I believe you can find reprint factory manuals right here at Iboats.
