RobertThoreson
- Joined
- Jun 12, 2015
- 145
Ok so I have a 58 fastwin 18 pulled apart to put new seals in, ordered the kit and I'm kinda lost. I ordered kit number 18-2684. A few of the seals iv done already; one behind prop and the o ring right by it, and the one right below the water pump but the one that came out was 1 piece, and the only seal(s) that fit the driveshaft were of a 2 piece design I'm guessing. Now there's a fat o ring for the shift shaft, but the ones that I'm not sure of, 2 nylon washers,one 1/4in o ring, another seal the same as the prop shaft seal, another large o ring like the one on the prop shaft seal housing but it's thinner and 2 fabric washers that don't fit the fill/drain plugs.
