Hello, I have a 1988 beretta ss with a 5.7l and a 280vp. I was in the process of changing out my intermediate shaft bearings and I removed the bellhousing to do so. I ordered the bearings and the 2 seals 958860. I got ran into a problem with one of the seals. The seal on the U-joint side does not fit tightly into the bellhousing. There is space between the wall and the seal when inserted into the bellhousing. The seal on the engine side fits tightly. Both are the same part number 958860 on the package. Is there supposed to be this gap, as the one that I took out was tough to remove and there was not a gap between the walls. I cannot reuse that seal cause it got ruined. Someone please tell me if this is how its suppose to be, cause out of all the people, I hope that I did not get the wrong part sent to me in the right packaging. If i reinstall the engine, would I still be able to install this seal if I had to reorder another? Thanks.
