sealent 1987 four winns
jdejongh
I have a 1987 four winns and where the drain plug fitting is in the transom it appears that the sealent is bad.... the fitting is a plastic fitting that is held on the transom with 3 scews and has an insert to screw brass plug in. can anyone reccomend what type of sealent i use to seal this plastice fittiing on the transom? thank you
