sealer for boat
wayne h
i have an aluminum v-hull rivited. it does not leak but i see that the sealer in the inside of the front of the boat where the 2 peices of aluminum meet (at the v) is getting old and cracked up can i just put new sealer over it ? or do i have to clean it all out.remember it does not leak and i hate to dig out all the old stuff and maybe make a leak. anyway what can i use for a sealer?
crazy charlie
Re: sealer for boat
The best and the strongest is 3M 5200 You should clean the excess sealant off and get the aluminum cleaned up with a scotchbrite pad.Wipe the area with alcohal or acetone and apply the 5200.I used it in place of a weld for years and it held and was watertight. Charlie
wayne h
Re: sealer for boat
because it looks really back its all cracking and falling out.some of it was hard some was soft it looked like plumbers puddy.i removed all of it tonight and will seal it with the 5200 sealer does that come in big tubes? i wanted to repaint the inside of the boat and could not see painting over that cracked stuff
