Hi,
Firstly, thanks to everyone here - the effort, expertise and emotion people put into their boats is inspirational as well as better than watching anything on TV!
As a counterpoint to everyone else's perfection - here's my request for assistance.
I have an old boat (18' half cabin with a new engine - see my other thread! :facepalm
which serves us very well here in Oz. She's about 40 years' old, beat-up and does not leak a drop (now that I put stoppers in the fishing rod holders the PO fitted to the gunwhales.....). She may be old, but 33Kts is fine for us.
Motor is worth $10K, boat with motor is worth $9K, you get the picture.
The anchor hatch is a simple clamshell (wider at the rear than the front) over a lip on the deck (Photos 1 & 2). The lid/aperture has a 1/2" gap across the front so any wave over the bow enters the cabin fairly directly! (Photo 3). The sides of the lid are bowed-in (Photo 4) and grip the aperture at the midpoint (see diagram in photo 1) but have a small gap either side of that. The rear edge of the lid has a reverse-sloping piece that seals pretty well.
Viewed from inside looking forward (photo 5) you can see the uneven vertical and horizontal gaps between the lid and aperture.
So, my big problem - how to seal the hatch? I tried a simple gasket of silicone on the lid inner to meet the lip edge, but cannot do this accurately enough, so one point always lifts. The lid is not flat, the aperture lip edge is not flat and the existing strap does not pull down evenly or hard enough anyway.
I thought to put a lip seal horizontally around the aperture edge so the lid folds it down when closed. This may work on the front edge but not the sides (not enough clearance).
Current madcap idea is to cover the aperture lip with vaseline and with the lid lifted just a fraction at the front (0.01mm! and sealed with vaselined tape outside), squeeze lots of silicone into the gap from the inside.
Then smooth the inner edge whilst wet and leave it to set. Should separate OK once set and I razor off the external excess flush to the lid edge. The new tie-downs would compress the seal into place. Or not?
I don't want to spend much (if any!) money on this, I have time instead. The boat is not worth $300 for a new hatch plus the odd-shaped hole makes this difficult.
I know I need better latches - maybe the rubber toggle types on the inside (we rarely anchor!) to hold the front corners down better. Can anyone suggest an alternative that can be opened from both sides of the hatch?
All suggestions gratefully received!
Thanks in advance.
A
Thanks in advance.
A
