tidesright
- Joined
- May 5, 2003
- 28
I just bought an early 1980's 19ft MFG caprice. It has a 1999 mercury 90hp outboard installed in 2000. The previous owner was ederly and passed away in 2003. We purchased the boat from friends for $1000.00.(boat, motor,trailer) She runs GREAT. The motor is spotless and estimated with less then 40hrs on it. It has been serviced by a local marine. Now that I have givin you the backround can you help? My problem is there is a rectangular access hatch in the floor which im told is the fuel tank access. It is screwed fast but the gasket material between the floor and the hatch is about 4inches short and leaves water in. There is a soft spot starting in this area. Im not sure im ready for some of the fiberglass repairs I have read about but I would like to replace the gasket to stop anymore water from getting around the hatch. Also, is there a simple fix for this soft area or does the softness indicate that the stringers in this area are rotting.
