O.K. you got me confused here. You've carpeted the panels and stapled on the back side and now you want to install them by screwing them to stringers. If that's correct then I don't understand the worry about the staples unless you didn't use monel or stainless staples in which case they will rust out in a year.When I reinstall the carpeted wood floor panels in my boat how do I seal the screw holes. I don't want a blob of sealant on the carpet at every screw hole. Any suggestions? Also what to do about the staple holes?
OK. Just seal them up with a little 3M 5200 and you'll be fine. I just put a little on the screw threads so as not to make a mess, it doesn't take much to do the job.I'm sorry I really didn't explain very well. My concern is water penetrating the wood panels through the screw and staple holes. I spent hours covering the wood with epoxy and fiberglass and don't want it to rot.
Think about self adhesive velcro to hold carpet to wood deck. screw the wood down then velcro the carpet to it. no staples no screws thru the carpet. Change it any time you like without lifting the deck.I'm sorry I really didn't explain very well. My concern is water penetrating the wood panels through the screw and staple holes. I spent hours covering the wood with epoxy and fiberglass and don't want it to rot.
Only problem with that is that now you have to have all of the carpet edges bound or it will unravel on you. We do a similar thing with our Lino decks except we use snaps to hold the carpets down.Think about self adhesive velcro to hold carpet to wood deck. screw the wood down then velcro the carpet to it. no staples no screws thru the carpet. Change it any time you like without lifting the deck.
Use 5200 as said above a little will go a long way ....
