Sealing slow leaks on oldish RIB?
CamaroMan
Hi all - got my first rib last month.. Just got motor setup nicely (still have to decarb it).. I did some leak detection and found one micro pin leak which I successfully fixed with superglue, and one seam was leaking badly which I reglued - one valve was also leaking slightly. Now I cant seem to find anything but boat still deflates slowly overnight -
I have some liquid latex to put in.. but its a semi rigid and I cant flip it around..
Any other tips? I heard I could maybe spray a coat from the outside? Although thats a biggish job - has anyone have luck with the latex method?
Sea Rider
Inflate all tubes to be firm, spray soapy water on them and check for small air leaks to know leak size. If small a tiny droplet of superglue works fantastic well, if larger will need patches and proper glue.
Happy Boating
gwozhog
No Title
Get your hands on a bottle of snoop from any HVAC Supply house and you will find your leak. It is 10 times more sensitive than soapy water. I do HVAC work so finding leaks is my expertise.
