I just recently purchased a 2005 Stratos 180FS. Had it out twice and both times a couple gallons of water came out the drain when I pulled the plug or pumped out with the bilge.
After closer investigation, I found 3 low screws from a previous transducer that had not been sealed. Also found one of the swim ladder brackets had been tweaked so I removed it to straighten and found both brackets never had the screw holes sealed real well. I plan on using 3M 4200 on the brackets, screws and holes before replacing. That should seal any leaks in these spots.
There are also two cracks at the top of the transom near the metal trim cap. The motor is solid and I don't think this is a problem, but would like to seal these up myself if I can. Could I seal with 4200 smoothed in and over the cracks or use something else like Marine-Tex epoxy putty? Any other ideas?
Thanks for your help!
