seals to replace
zeber
I am changing the prop shaft in mt 25hp johnson J25TECRD it is a 1984 and i wanted to know what all seals i have to replace in the lower unit i see some o-rings and the seal around the gear box and i seen some prop shaft seals on line but not sure were it would be dose this come in a kit or do i have to buy them individaly any help thanks
Vic.S
Re: seals to replace
There is a pair of seals on the prop shaft and an O ring on the head assembly.
Another pair of seals on the vertical drive shaft
An O ring on the shift rod and a gasket below the bush
And the spaghetti seal between the gear case halves
Find all the parts listed in the parts catalog at http://shop.evinrude.com/
There does not seem to be a seals kit listed.
jasper60103
Yes, I would order the kit and replace all of them.
Also, get a tube of 3M #847 Scotch-Grip adhesive for
putting it back together.
