Sear ted williams 7.5 lower unit/prop?
phrozin
Model 217.58890
Replacing the impeller on it the lower unit dropped down fine.. My problem is.. I put it all back together and now when i put it into gear i have no spin on my prop. It did spin just fine prior to replacing the impeller. Ive taken it apart 3x now to make sure it line up correctly.. Did i stripe the clutch somehow?? Please help..
brim_buster
Re: Sear ted williams 7.5 lower unit/prop?
send me a message with your email and I will send you the manual. I doubt you stripped the clutch, sounds like it needs adjusted. page 9 of the manual tells you how to adjust the shift linkage.
mario27weld
Thanks for the manual and the advice, next time ill start a new thread, happy Friday!
