Re: SeaRay fuel gauge issue
The gauge external covering is black plastic and the strap on it matches. I have tried what you suggested already and no luck. Once over, I removed the gauges one by one. Diagram is right, but my 12V wires from the switch are all white in color. Here is what I have...with the white 12V hooked to 'I', pink to 'S' and the black from sender to 'G', gauge does nothing at all. No Light either, but I have 12V measured to ground at the 'G' pin and 'S' pin. If I add a ground wire to the 'G' pin, gauge goes straight to below 'E' and I have .03V measured at all 3 pins on the gauge, but the light works...
You need to pay more attention to the sender wiring. You said you have a black wire from the sender to the "G" terminal. WHY?? The ONLY wire you have from the sender is the PINK wire. There is no ground FROM the sender. The metal flange on the fuel tank sender should have a ground wire going to the NEG terminal of the battery or to a ground buss at the stern - not all the way up front to the "G" terminal on the gauge. Electrically thats the same as running a wire from the flange but that still leaves you without a ground for the gauge. Stop experimenting and start diagnosing.
1) Locate the ground wire in the ENGINE HARNESS. That is the wire and the ONLY wire that connects to the "G" terminal on the gauge.
2) The PINK wire is the sender wire and is the ONLY wire on the "S" terminal. It does not ever measure 12 volts to ground or anywhere else for that matter.
3) The WHITE wire is the only wire on the "I" terminal.
4) You mention not having ANYTHING on the "S" or "G" terminals. What do you expect to read on the "G" terminal. And measured from the "G" terminal to what?? Ground is ground. You can't measure voltage on ground. You can measure 12 volts relative to ground or sender voltage to ground but you cannot reference ground to anything.
5) Go to Radio Shack and buy a 100 ohm resistor. Disconnect the pink wire at the gauge ("S" terminal). Connect the resistor between the "S" and "G" terminals. Now turn the key on. The fuel gauge should read about 1/2 full. If it doesn't the gauge is toast or you still have the +12 volts and ground wiring miswired. If the gauge now reads half full, you have a sender, sender wire, or a sender ground wire issue.
