Search Function
Vintin
How does it work?
I never get anything.
For instance, QD-21
oops!
Re: Search Function
actually the search engine works quite well....just takes some getting used to
but you have to give it the correct words......
or a user name to narrow down the fields....
Bob_VT
Re: Search Function
Yes for get the dash and just search for qd21 and you will get results.
Now the search will not work with 3 letter search terms........ or it would return too many results so the 4 letter is the minimum allowed by the forum software.
GA_Boater
Re: Search Function
You can use Google outside of iboats to search for less than 4 characters within the site. "3hp site:forums.iboats.com" in a Google search box gives all 7000+ references to 3hp. Sometimes what you want is less than 4 characters but don't bother to search for common terms. Hope this helps.
Don S
Re: Search Function
Search for oil or 470 on the IO forums or all of the forums for that matter, there are a few thousand on each, but neither shows anything using search.
