Re: Sears 1971 5hp 217-58992 will not run above idle
did you do a compression check before pulling the head? If it had good compression then likely pulling the head was a bad idea. luck finding a head gasket. Pull the flywheel and look at the coils, points and condensor. dirty points or a bad coil or a weak condenser can all cause the problem you are having. a motor needs three things to run, spark, fuel and compression all at the right time. New points can have film on them, condensors even new can be weak. especially if it's old stock. They leak just from sitting. Good luck to you
