Sears fuel pump
djmcelwain1
I don't have much info on this motor, so if anyone knows anything please help!!! My friend gave me a motor off of his Sears Gamefisher boat. I believe it is the motor that Sears sold with the boat, I don't know for sure. All the info that I can find on the motor itself is: Chasis# 217/58632-0, Serial# 7K045533---Sears Robuck and Co. There is also a tag on the motor that says: 381L Tecumseh 7014. That is all the info I have. So now the question. The motor needs a new fuel pump. One piece is worn out, and no one seems to be able to locate it. Anyway, does anyone know where to find a fuel pump. What is the horse power on this motor. And if I can't find a fuel pump, can I go to a different type of pump. Thanks for ANY and ALL help. Dan
rickdb1boat
Re: Sears fuel pump
It's a 15 HP. <br /><br />Parts:<br /><br />Certified Parts Corporation<br />1111 W. Racine St. <br />Janesville, Wi.53547 <br />1-800-356-0777<br /><br />Also, try your local lawn mower shop for parts for tecumseh engines...
djmcelwain1
Re: Sears fuel pump
Thanks, i'll give it a try. If I can't find what I need, I'll be back with more questions. Thanks again, Dan
djmcelwain1
Re: Sears fuel pump
No, just what is listed above. I'm totaly uninclined mechanicaly, so I haven't tried to do anything with it yet. My friend, who had it before, is good with this kind of stuff and is the one that told me it was the fuel pump. He tried to located parts and failed. That was before he had internet though. I figure now it's a little easier to search nation wide. Anyway thanks for all the help. If you, or anyone else thinks of anything useful (or not) please let me know. Dan
mellowyellow
Re: Sears fuel pump
Dan,<br />it's a tecumsah powerhead. local mower/tractor<br />repair place should be able to get powerhead parts.<br />same parts, but "marine" costs more...<br />good luck,<br />M.Y.
djmcelwain1
Re: Sears fuel pump
Well gentleman, and women, thanks to you I have one heck of a start on this engine!!! Through your help I found that I'm the owner of a: 1977 Sears gamefisher 15hp motor. It needs a fuel pump, Part number 631721. The only trouble I have now is where to find one. I have checked several online suggestions, and none have panned out. If anyone thinks of something new please let me know. In the meantime I'll check local shops. Thanks so much. You all are the greatest!!!!!!!!!
djmcelwain1
Re: Sears fuel pump
I have no idea what cheap or for that mater expensive is. Any idea what one would cost? A good guess would be helpful!
mellowyellow
Re: Sears fuel pump
same tecumsah engine in many lawn tractors.<br />1) get a service manual<br />2) pull the pump and take it down to local tractor<br />/lawnmower repair place. they should be able to<br />match it up.<br /><br />ps. how do know it needs a pump?
djmcelwain1
Re: Sears fuel pump
My friend said it runs great as long as you continue to pump the pressure bulb. He had it apart and decided the problem was the diaphram. He looked forever and couldn't find one. We figured it might be easier to locate an entire fuel pump. So far no luck with i-net or local mower places. The pump is no longer made by tecumseh. Let me know if anyone has anymore ideas. You gus are all great!!! Thanks Dan
mellowyellow
Re: Sears fuel pump
I would be looking for a pump rebuild kit, not <br />another pump. a bad primer bulb would cause same<br />problem BTW.
fone_man
Re: Sears fuel pump
Sears Info obtained from http://www3.sears.com/ <br /><br />Sears Parts Page <br /><br />Model Number<br />217586320 <br />Model<br />SEARS 15.0 H.P. <br />Description<br />GAMEFISHER OUTBOARD MOTOR<br />Brand <br />CRAFTSMAN <br /><br />PUMP, FUEL 631721 <br />REPAIR KIT, FUEL PUMP 631722<br /><br />Hope this helps also can get parts list & diagrams from this site.<br /><br /> :cool:
djmcelwain1
Re: Sears fuel pump
Thanks Fone_man, but Sears no longer has/makes most parts for my motor. That's why my in trouble with this motor. If you come up with anything else it would be appriciated. Thanks, Dan
mellowyellow
Re: Sears fuel pump
pretty sure the motor you have was made for sears<br />by Eska. the link I gave you above lists the<br />diaphram for eska as avail.<br />maybe somebody else can chime in here and confirm<br />this for me??? is it Eska?
rickdb1boat
Re: Sears fuel pump
Any small Johhny/Rude diaphram pump will work. Just get one for a 15 HP Johnson and hook it up.
mellowyellow
Re: Sears fuel pump
sent an email to the link and yes, they carry<br />the parts! here's their reply to me:<br /><br />I do stock Carb parts for that motor.<br /><br />Carb Kit ES630753 $24.90<br />Fuel Pump Element ES630953 $7.06<br />+ S&H <br /><br />ps. the motor was made by eska for sears.
