I need a new prop for a 24 lb. thrust Sears Gamefisher trolling motor. The one on there now has a blade that is bent a little and it causes a lot of vibration. It's a 3 blade prop, made out of some sort of plastic or composite.
The diameter of the prop is about 8 inches, the outer hub diameter is 1 1/4 inches, the outer hub diameter can't be any bigger then this because part of the hub fits into an indent in the motor casing. Also, the shaft size is 3/8 inch and it's a clockwise rotating prop.
Does anybody have one they want to sell, or know anywhere I can get one?
Would Sears have it, or be able to order it? This is an older motor that we got at a rummage sale for $5.00 but it works well, except for the vibration.
Here are some pics.
From the front
From the back.
Closeup of the hub.
Thanks,
Adam
Here are some pics.
From the front
From the back.
Closeup of the hub.
Thanks,
Adam
