sears gamefisher 7.5 cooling?
Millerdvr
was wondering what type of exhaust cooling this engine uses, impeler or the splash type.
it is a serial number 217585... type.
Thanks,
Chris
And the plate on my engine says to use a 50:1 fuel to oil ratio. I see alot of questions about this , I generally use a 40:1 just for the hell of it.
steelespike
Re: sears gamefisher 7.5 cooling?
Model number should have 2 or 3 more numbers.
But It is probably an Eska built motor.It uses a pump and water should mist out the relief holes on the leg.If your label says 50:1 it should be fine.My 89 aftermarket service manual says 32:1 using TCW rated oil.TCW3 rated oil is fine.
