Re: Sears - Gamefisher Outboard Motor 1.75
Stargazer hi, did you manage to change the gear oil,on mine it was a pain,see it only has one drain hole,in the manual,they recommend you remove gear housing by removing the two bolts,when I removed the drain bolt,the oil stayed in there,even upside down,eventually I found a meathod to syphon the oil out with a thin hose,I even used the hose to add oil,if not you have to do so drop by drop.I wouldn't take off the housing,what if you damage the seal,plus its probably stuck on there pretty good,I tried removing mine,gave it a few taps I gave and just put the bolts back,lol I made a new vidI raised the transom,youtube "transom mod"if not try boater 305 P.S. for syphon trick I used a suringe used for greasing your reels,I added a skinny hose to that,it was a bit slow but worked good,I got the hose all the way to the bottom getting out all the old oil,I even flushed it and drained it again with a bit of new oil,I stuck the hose in there to fill it,1/2 ounce at a time.I layed the motor down with the handle up,so don't tell me you have 2 running 1.75's
,I'll be so jealous
Carefull you don't push it past its maximum 8000 rpm,I'm not sure but I don't think our motors have a rev limiter mine is m#298586180,
check boater 305 on you tube see his channel to see my twinn 1.75's runningYes I said twinn I got another,maybe one day I'll run a 3hp inbetween the 1.75's,or I'll get another 1.75 for tripplets lol [video]twin motors[/video]copy this link for youtube under "boater 305
