fishnbab69
- Joined
- May 11, 2011
- 6
I just inherited what I believe to be a 1985 Sears Gamefisher 9.9 (217.586260). I can get the engine to turn over and run but according to the manual it is showing I should see a tell-tale out the right rear underside of the engine. I also see exhaust relief holes and water outlets on the column. Where exactly should I be seeing any water coming out of this. I have ran across some other threads that say some of these are air cooled engines and water cooled for the exhaust leg. I have just received a new impeller and have removed the lower to replace it. The drive shaft and water tube came out easily enough. I tried to follow the water tube up to to see where it winds up but did not remove the powerhead. Any help is appreciated.
