Sears Outboard
fast525
Anyone know what year this Sears model # is 66020 . Thanks as always . Jeff
steelespike
Re: Sears Outboard
I dont find that number, my reference only goes up to 72. Double check your numbers and maybe a discription would help.
fast525
Re: Sears Outboard
It's fairly old I'd guess 40s'-early 50s' mayby 4 hp . I'm need a water pump for it and don't know what years interchange if any . Do you have any suggestions . The "pump" that's in it is rubber , round , has an ear on it , about a 1/2 inch thick and works off a cam on drive shaft . Thanks ,Jeff
scotiany
Re: Sears Outboard
Don't know about your particular engine but the Sears from 55-65 were made by West Bend and McCulloch. They were formally known as Elgin. Also, there was one model made by Clinton in 1965
steelespike
Re: Sears Outboard
If the motor is an early Elgin Number would begin with 571 Scott McCulloch 574 Early Elgins were olive drab green with a slab sided oval built in tank.Small McCulloch 3.6 has a squat oval built in tank<br />not sure of color.<br /> Give us color,Metal or plastic cover,no.<br />of cylinders,Built in or remote tank.<br /> Have you checked really carefully for numbers<br />usually on the mounting clamp.
The Rookie
Re: Sears Outboard
Gents,just purchased a 1971 sears 5h.p.w/217-58992,my thouhts are to re-do the entire motor top to bottom,seems head gasket is small issue and correct carb kit is another,according to some posted forums,respectively.Does this motor have water pump impellor?Need a little direction with the rebuild as parts are concerned.Sears parts are limited availability.Thanks loads,your opinions and direction,is appreciated.
M
mrcrabs
Guest
Re: Sears Outboard
Look under the Eska files for links, Eskaman2008 on ebay can help you, certifiedpartscorp.com is a great resource, but first get a repair manual...you might want to join the http://groups.yahoo.com/group/eskaoutboards/ and check the files section...what model is your engine? look for a tag behind the carb, you can also cross reference your sears model at http://home.earthlink.net/~brixent/index.html to get more info.
And start a new thread, this one is 7 years old;)
