Re: sears ted williams 7.5 HELP PLEASE
and the carb bowl does leak a little bit with the screw at the bottom.. i have a different bowl without the screw.. dont know if its necessary to have..
depending on what screw your talking about, some bowls have a drain valve but if its the power jet you will not be able to switch between a emissions jet and a adjustable jet, and yes get rid of all the fuel lines and rusty old crap and buy a briggs type plastic 1/4 in shut off valve and a small inline filter for 2 cycles, I like the yellow clear line.
and clean the filter basket behind the flapper gasket ( you will need to replace that most likly,)
I would need to know the outboard model number before I could say for sure on the oil but if its a AV817 640 series engine then yeah 40ish depending on cowling type ( some have better air flow than others), if the impeller is shot 16:1....lol
if you search this forum you will most likly some up with a sierra part number for the impeller.
