Re: Seat Removal 2004 Ranger 195VS
Well 264Douglas, I can't help you on the seat issue, I've got a similar question posted for an earlier model. But, I think I can tell you why you are not able to upload photos. The most likely reason is that the picture files are too large for the forum's guidelines. When you attach files the pop-up panel shows the largest file size that the forum will accept. It also shows the permitted file types, you could be trying to upload a non-supported file type.
If the file is too large you would need to run it through an editor to reduce the resolution to what the forum accepts and/or convert the file type to a supported type.
Regards...
