Seat screws working out.
wing dam
I have a 06 Parti Kraft. We trailer the boat everywhere and I have noticed that the screws in the seat hinges keep working out. I tighten them down and back they come out. Anyone have a idea to keep them in place?
I am sick of going to open a seat and have it fall off the hinges due to loose or missing screws.
Thanks
tashasdaddy
Re: Seat screws working out.
little thicker screw. or take a wooden match stick, stick it in the hole, and break it off, then reinsert screw.
imported_John o
Could also add a lock washer beneath the head of the screw. That way they won't vibrate themselves out
tashasdaddy
lock washer work best on bolts, not screws.
fishon13
Had the same problem a little jb weld fixed the problem. mix up and place on threads try this before going to larger screws.
The_Kid
Fill the hole with silicone caulk and then tighten the screw. They won't vibrate out and you'll be able to remove them if you need to.
