proline2550
- Joined
- Nov 20, 2004
- 22
Just got back from a 3 1/2 hour, one engine ride in 3 to 5 footers, fun! 2 trips ago, while in rough water, I had one engine become hydro locked and was unable to turn it over until removing the plugs and blowing out the naughty H2O. After getting a look at the risers and seeing their condition, I was prone to blame them for the problem. I changed all four on both engines. That was three, calmer, trips ago. Today, while fishing a reef site in very snotty ocean, both engines had a hard time starting seemingly from a low battery, both mind you. I was able to start them and we went on to the next fishing site. I did not shut off the starboard engine, so the batts would charge. When the time came to start the port engine. BAM, hydro locked. I pulled the plugs and cleared them out. Can anyone else think of a way that seawater can get into the cylinders other than a rotted riser? I think that the answer has to be the check flapper in the exhaust at the bottom of the elbow, after the riser. Some how, when the boat is in rough water and rocking the water has to be forcing it's way in and down through the exhaust riser and through any open valves once it is shut down. The engines are 1994 mercruiser 4.3 liter, with alpha I gen II drives. Fresh water cooled.
