Seawater pump wobbles-wrong balancer?
jgresham75
purchased by boat used. Ever since then, my seawater pump does a slight wobble. It is screwed to balancer w/3 oem bolts. However, the bolts fit loosely in the holes of the pump so that it is hard to set the pump centered on the balancer-therefore, I got a wobble. It is possible I don't have an origianl balancer as the previous owner had the engine replaced.
I guess my question would be (from anyone that may have a similar setup) does the oem balancer have some sort of centering or line up mechanism that will center the pump? Thanks in advance.
Don S
Re: Seawater pump wobbles-wrong balancer?
If the bolts are loose and the pump wobbles, you probably don't have it on the balancer properly.
