- Joined
- Jul 18, 2011
- 18,137
On my old boat (Formula 330 SS) I've gotten used to having 2 boarding ladders via my special swim platform. On my new-2-me boat, it only has one boarding ladder off the port side of the swim platform.
I planned to add a second boarding ladder on the starboard side. I toyed with a few ideas, one of them was to make a full duplicate of the port side ladder, which is concealed with a hatch. It looked to be a bit involved, considering the little time that I have until 'launch day' (when ever that is). I also considered under the swim platform ladders, but the way the platform is designed on this boat would make the final step fairly awkward, if not impossible.
As a compromise, I came up with a design of a pocket ladder at about the height of the top of the swim platform. It would involve essentially an open ended 'box' that housed the swim ladder. The 'box' would be installed in the open space just under the swim platform surface and protrude out the side a few inches. The box would provide the water tight seal that the swim platform needs.
Here is my design . . .
My PaperMate version of a CAD system . . .
The pieces . . .
I cut a big hole in the boat . . .
Test fitting the box & ladder. . .
The rubrail would provide some added buttressing for the ladder when under load so it would not tend to swing under the swim platform.
The ladder 'assembly' will be held in by a combination of fasteners and adhesives. Two fasteners from the top of the swim platform and several along the rubrail.
I used my 'laser focus' to mark the holes for the two top bolts . . .
The holes were spot on . . . (minor miracle)
Today, it is a run to the hardware store to get some more fasteners and 4200 adhesive. Then finish it up.
The pieces . . .
