I have a 1976 120 Mercruiser. It starts OK, runs rough while warming up but smooths out as the choke opens. Just when it starts to get warm it shudders and dies.
This started a few weeks ago. At that time I was able to run upstream to a fuel pump and it ran fine, but one the way home I tried to get on-plane and it just lost all power. The engine shuddered and sputtered the last mile and died as I pulled up to the dock upstream from my house. I thought it was water in the fuel, so I added a water separator. I got the engine warmed up and running nice and my wife got in with me and we made it about two or three hundred yards, not even out of the no-wake zone and it started sputtering so I headed home. It died just in time to glide into the slip. The next day I tried getting water out of all of the lines and dumping out the carburetor. It started fine, ran a bit rough until the choke opened, warmed up nicely, then died sitting right in the slip. It was getting progressively worse. So I took the carburetor apart to see if some sludge had somehow gotten inside of it, but it was pristine clean. Put it all back together again (yes, with a carb kit) and tried it again a few days later. Same thing only this time it dies just as it is getting warm to the touch.
So what could this be? There is a new fuel pump and rebuilt carb, new fuel, water separator, filters. I no longer think fuel is the issue.
So what happens as it warms up? The choke opens. But the choke on my current carb is electric and has been open for a while when this problem occurs.
Also, the thermostat opens as the engine warms up. So where does the water circulate before the thermostat opens and where does it circulate after the thermostat opens? Could water somehow be getting into the cylinders only when the thermostat is open?
A bit more background: a few years ago (right after I bought it) I had to have the exhaust elbow replaced as the water jacket had rotted through. Last year the water jacket on the head rotted through. Does this sound like the exhaust manifold could now be rotted through?
And if the exhaust manifold is rotted through does that mean the block is next?
Is there anything else that can be causing this particular problem? Hopefully something I can afford!
Thanks,
--FatBear
Thanks,
--FatBear
