scout-j-m
- Joined
- Jul 31, 2009
- 642
As the subject line indicates I'm having trouble deciding where to go from here with my 1994 70HP Force outboard. My current situation is that I have both very low compression on all cylinders (110, 110, and 90 psi) and a faulty ignition which delivers a weak and inconsistent spark to the lowest compression cylinder. So basically this motor is about to die any day and just doesn't seem worth putting any money into to me.
It is powering a 1994 17' Spectrum Dominator. I still go fishing in it as the boat itself is decent in that it doesn't leak, has a good trolling motor and batteries, and has decent carpeting and decking. It would suck for it to die on me out on the lake but I stay within trolling motor range typically.
My predicament is whether or not to try to fix the Force up anymore to make it last me a few more years, ditch the Force and replace it with a used 60-70HP outboard, or try to sell the boat and Force together. I'm leaning option two as I don't see trying to fix the outboard as a very smart move and I'm not sure I could even sell the boat/motor together as it is without essentially giving it away.
There is a craigslist ad nearby for a 1976 Mercury 70HP with controls (no power tilt/trim) which is advertised as having power loss at WOT but says compression is 140 psi across all three cylinders and has new power packs and plugs. It also looks pretty sharp for its age. Is listed for $500. I really don't want to replace the Force with another project motor but anything that has good compression is enough to get my attention as it means I can likely fix it myself.
Just curious what members here may do in my situation...
