Re: seems like prop is spinnig out.. but its not the prop ???
Seems to be a tad bit of confusion. What we suspect is ventilation, not cavitation. The two terms are commonly interchanged, but they are two entirely different phenomena. Ventilation occurs when air pockets caused by turbulence develop around the prop and cause it to momentarily lose its bite. When this occurs the prop can feel as if it's spinning out. Ventilation is common with barges because there is so much surface area and so many angles making contact with and churning up the water ahead of the prop. It is also normal to experience greater incidence of it in rough water. Not sure what was meant exactly by "exposure to the atmosphere," but I don't think that's what we're talking about here. In any case, 20 mph or so is about right for a 24 footer with an older 90 horse. Some may get a few more mph, some less, but that's about all it's fair to expect of your rig. Finally, if you're not sure about the prop pitch we can speculate as to whether experimentation is in order, but we'll need some more info first.
