Team Johnson. Like a dummy, I let my '65 40hp sit for 2 1/2 years. Not my fault it sat .. here in Austin, due to drought, no ramps reached the lakes. Definitely my fault, I didn't pull the plugs and shoot oil in the cylinders, and turn it over now and then. It's froze solid. What I have tried:
1. 2' breakover bar with a 1 1/16 socket on the flywheel. with all my might.
2. seafoam penetrating oil in cylinders, leave engine tilted so oil sits against the rings, and then every day or so see #1 above.
3.. Coke in the cylinders. then see #1 above
4. Very cheap (electric) impact gun on said 1 1/16 nut
5. Tried to pull heads just now. All bolts out, pounded as hard as I was comfortable with rubber mallet, but they won't budge.
What I have NOT tried is hit the (new) starter to see if that will break it free. A bit afraid I'll booger flywheel teeth.
Thoughts?
Thoughts?
