Seized engine
clasavi
2016 383 stroker with 20 hours
Last years I ran the boat from the marina to the ramp with no issue. brought the boat to the house drained the water from the manifolds, block and stored it. This is year the engine is locked up. Is that possible?
I removed the lower unit and the engine is still locked/seized
No sign of water in the oil
Start with basics
Is your battery fully charged?
What happens when the starter engages?
Do the battery cables heat up?
Can you turn the motor with plugs out by the belt?
clasavi
Start with basics
Thank you for the reply
1) Batteries are charged
2) I haven’t checked the cables but will do
3) starter engages and I get one clunk
4) I cannot turn the motor with plugs out
5) I did spay some PB blaster and let it sit for couple of days. Still not turning. I’m using a crowbar at the fly wheel and still can’t turn it.
Doesn't sound good. It wouldn't take much water to seize a motor
You've done all the checks. Lets hope PB loosens things up
clasavi
Thank you. It’s nearly unbelievable or a case of really bad luck.
when you drained the block, manifolds, etc. did you prob the holes
MY thought is there might be a small intake leak and had just enough to get a small amount into a cylinder. If that's the case, the PB sitting long enough should free it up over time
clasavi
update. i got the engine to turn!!! ty
one more question - when reinstalling the lower unit, do I need to use a sealant?
Don't know which drive but Alpha or Bravo needs to sealant
Ayuh,..... The Alpha needs the gasket kit, 'n I believe the Bravo is sorta an o-ring affair,....
Neither need sealant,.....
