I have a 20 ft Hurricane deck boat with a 240 hp Mercruiser 5.0 L engine. It has an alpha outdrive.
Currently the boat has a Michigan Wheel prop on it. Part # 992203, 14.5 x 18 RH 4 Blade prop. The prop is a bit dinged up but not too bad. I would like to replace it with a prop that will get me out of the water fast (that is why I have a 4 blade) and get me a decent top end speed. Currently with this prop the boat runs about 41 mph WOT. The WOT RPM's are only 3000 though. The bottom of the boat is very clean. I do not leave this boat in the water.
Any recommendations on getting the WOT RPM's up?? The books says I should have 4400 to 4800 rpm's at WOT.
Is this the right prop??? Also, anyone like any particular brand of props??
